Oil Catcher Drain Pan - V-Twin 16-0256 - OEM 62700199 - Twin Cam 2017+
OEM #: 62700199
Oil catcher pan is used when removing the oil filter to avoid spilling the oil onto the engine cases. There is a 12 inch tube to direct the oil flow into oil drain pan.
| 2017-UP | FL |
| 2017-UP | FLT |
