Oil Drain Spigot Tool - V-Twin 16-0096 - Twin Cam Touring 2009+
Oil drain spigot tool with a red anodized finish keeps the fluid off of the frame.
This tool channels the transmission fluid from the bottom of your transmission case into the drain pan instead of onto your frame. The tool has a helical design that locks the tool into the frame cross member and around the drain plug. This allows you to remove the drain plug through the center of the tool. Tool is not heat treated.
| 2009-UP | FLT |
