Inline Spring Fork 1 Handlebar Chrome - V-Twin 49-0899
Standard type chrome Spring Fork handlebar with inline with 1 inch bar ends for external inchfast inch throttle applications. The forged triple tree is welded in place.
For use on stock style original type Spring Forks with an inline stem. *NOTE: Center forging surface is not polished before painting or plating **NOTE: Forged tree has holes on each side for wiring or cables. ***Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Rise to Center: 5 inches
- Width Tip to Tip: 38 inches
- Thickness: 1 inches
- Rise to Grip: 6 inches
- Center Width: 5-5/8 inches
| 1936-1946 | EL |
| 1941-1945 | FL |
| 1941-1957 | G |
| 1938-1945 | UL |
| 1936-1952 | W |
