Gas Tank Fuel Rod Alignment Tool - V-Twin 16-0182
519 ENTRIES 🎟️
519 ENTRIES 🎟️
Gas tank fuel rod alignment tool is hex type with parkerized finish.
Tool can be used without removing gas tank from the bike! This hex tool allows technician to use a box wrench to tip the lower threaded insert and center the rod while checking alignment. Tank will be more secure while still bolted in place which decreases the risk of damaging it during the alignment process.
1936-1952 EL
1941-1965 FL
1936-1956 G
1936-1952 W
