Intake Manifold Conversion Nipple Set - V-Twin 35-1707
Intake manifold conversion nipple set adapts 1-15/16-20 threaded nuts to 1-11/16-20 cylinder ports. Set has a zinc plated finish.
These threaded nipples allow the WR style manifold to be used on stock WL or G 45 inch cylinders. This allows use of a 4-bolt Overhead Valve linkert carburetor. Sold as a pair. Collar is threaded inside for WL and outside for larger WR.
  • Suggested to use with Intake Manifold
  • Allows use of 4-bolt WR Manifold
1941-1973 G
1941-1952 W
