41mm Fork Slider Assembly - V-Twin 24-9995 - OEM 45915-86 - Big Twin 1986-1999
OEM #: 45915-86, 45916-86
Hard chrome fork tube assembly with polished sliders and components installed. Assembly has an overall length of 29-1/2 inch.
The distance from center of the axle to the very end of the leg to the cap at the end measures 31-13/16 inch from the center axle to the end of the legs measures 29-1/4 inch.
- Overall Length: 32-1/4 inches
- Drain assembly lube. We recommend 20 weight oil for average conditions. The amount of fork oil per leg is 11-1/2 ounces.
| 1986-1999 | FLST |
| 1986-1999 | FLSTF |
