Rocker Clutch Bracket Parkerized - V-Twin 49-0476 - OEM 2410-36
OEM #: 2410-36
Exact Replica of the 1936 style rocker clutch bracket is the early bushing style using early cover and friction parts featuring a parkerized finish.
Restoration quality clutch lever bracket is exact replica for 1936 to early 1938 EL and UL models. The bracket is approximately 2 inch shorter than the Late 1938-65 types. Includes single bushing installed. NOTE: Pedal pivot position is lower than the 1938-65 versions.
| 1936-1938 | EL |
| 1936-1938 | UL |
