Cast Iron Standard Exhaust Valve Guide Set - V-Twin 11-1168
Cast iron standard exhaust valve guide set is machined to be used with 1981-1985 type valve guide seals and lower collar.
Guides are undersize on the inner diameter and will require fitting of valve stem to valve guide for proper clearance.
- Accepts seals and valve
| 1981-1984 | FL |
| 1981-1983 | FLT |
| 1981-1984 | FX |
| 1982-1983 | FXR |
