Factory Sample Standard Hydraulic Tappet Assembly - V-Twin 10-2089 - OEM 18522-53
$139.99
1119 ENTRIES 🎟️
$139.99 - $139.99
$139.99
1119 ENTRIES 🎟️
OEM #: 18522-53
Assembly is a set of four tappets that feature cylindrical surface fine grinding and precision fit with maxi-axle rollers and pins.
Outer diameter measurement is.7310. The larger diameter roller in these maxi-tappet assemblies increase the dynamic load rating by approximately 20%. NOTE: Sample parts may show marks from installation test and fitment. May require light modification to fit specific application.
  • Roller Diameter: 21.7 mm
  • Pin Diameter: 7.60 mm
  • Needle Diameter: 1.60 mm
  • Axle Width: 17.92 mm
  • Suggested to be used with Solid Tappet Adapter Set.
1953-1985 FL
1979-1983 FLT
1971-1985 FX
1982-1983 FXR
