Replica Zinc Plated Tappet Block Set - V-Twin 10-0988
Front and rear replica tappet block set is constructed from steel featuring a zinc plated finish.
The counter bore for the screws are recessed or flat at the bottom to accept non tapered screws. Use with allen cap screws as noted. *NOTE: Must order seals and gasket kit separately. Lifter bore is.7315. *NOTE: These are machined from the later model inchheavy inch style castings.
| 1948-1984 | FL |
| 1979-1983 | FLT |
| 1971-1984 | FX |
| 1982-1983 | FXR |
