Standard Rocker Arm Shaft - V-Twin 11-0540 - OEM 17435-39
OEM #: 17435-39, 17438-39, 17441-39
Sifton Knucklehead rocker arm shaft set.
Front intake measures 4-1/8 inch and has an actual ground surface of 4.115. Rear intake measures 3-5/8 inch and has an actual ground surface of 3.6. Rear exhaust measures 4-5/8 inch and has an actual ground surface of 4.6345. Front exhaust measures 5-1/4 inch and has an actual ground surface of 5.119.
- Shovelhead rocker arm shims may be used on the left side of the Knucklehead rocker arms to adjust end play. Available as (.005) (.007) (.015).
| 1936-1940 | EL |
| 1941-1947 | FL |
