Engine Pinion Shaft - Eastern A-24006-58 - OEM 24006-58
by Eastern
$119.99
$119.99
$119.99
1199 ENTRIES 🎟️
$119.99
$119.99
$119.99
1199 ENTRIES 🎟️
Eastern #: A-24006-58 · OEM #: 24006-58
Precision ground for correct fitment.
*NOTE: Must order key oil pump gear and key pinion gear separately.
- Suggested to use with Motor Sprocket Shaft Key.
- Suggested to use with Pinion Gear Shaft Key.
| 1958-1972 | FL |
| 1971-1972 | FX |
