Replica Oil Pump Assembly - V-Twin 12-9979 - OEM 26217-56A - Ironhead 1957-1966
OEM #: 26217-56A
Replica oil pump includes all parts assembled.
Includes alternator roll pin 3/8 inch clutch ball bearing oil pump snap rings Replica oil pump body oil pump seal inner oil pump cover plate cam chest breather gear scavenger gear idler gear feed idler gear feed gear key for oil pump gear check valve spring switch switch fitting straight gas/oil fitting hardware gaskets.
- Order hardware kit
| 1957-1966 | XL |
