Replica Oil Pump Assembly - V-Twin 12-1944
Original price $539.99 - Original price $539.99
$539.99
5399 ENTRIES 🎟️
$539.99 - $539.99
$539.99
5399 ENTRIES 🎟️
Replica oil pump assembly includes cast outer cover without rotator. Pump is fitted with the late type oil pump relief valve kit. Body is zinc plated.
Assembly will only work with 1941-1947 FL Knucklehead models. Cover has correct shape with external oil control for 1941-1949 models but does not use governor rotor. *NOTE: Lower right hand threaded hole is 1/4 inch x 20 thread.
1941-1945 FL
