Oil Pump Hardware Kit - V-Twin 12-0177 - Ironhead 1957-1976
$69.99
559 ENTRIES 🎟️
$69.99 - $69.99
$69.99
559 ENTRIES 🎟️
Kit includes oil pressure switch fitting pressure switch straight male gas/oil fitting oil pump check valve spring 3/8 inch clutch ball bearing drain plug oil pump dowel feed pin retainer half key gaskets and snap rings.
Order gears and oil pump body separately.
1957-1976 XL
