Oil Pump Assembly - S&S Cycle 31-6206 - Evolution 1992-1998
S&S Cycle #: 31-6206
S&S oil pump assembly with billet style bodies.
Assembly includes supply gears return gears drive shaft drive shaft keys drive shaft snap rings check ball check ball spring pressure valve pressure valve spring cover screws with o-rings hose fittings plugs screws paper gaskets and mounting hardware. Order breather gear and shims separately.
| 1992-1998 | FLST |
| 1992-1998 | FLT |
| 1992-1998 | FXD |
| 1992-1994 | FXR |
| 1992-1998 | FXST |
