Oil Pump Assembly - S&S Cycle 31-6203 - Big Twin 1973-1991
Original price $399.99 - Original price $399.99
$399.99
3999 ENTRIES 🎟️
$399.99 - $399.99
$399.99
3999 ENTRIES 🎟️
S&S Cycle #: 31-6203
S&S Billet oil pump assembly is for 1973-1991 Big Twin models.
Assembly includes supply gears return gears drive shaft drive shaft keys drive shaft snap rings check ball check ball spring pressure valve pressure valve spring cover screws with o-rings hose fittings plugs screws paper gaskets and mounting hardware. Also included is universal cover with top and bottom feeds. Oil line available separately.
  • Suggested to use with Rigid Oil Line Set for Billet Pump Zicad Plated
1973-1984 FL
1986-1991 FLST
1979-1991 FLT
1991 FXD
1982-1991 FXR
1984-1991 FXST
