Oil Pump Assembly - S&S Cycle 31-6200
Original price $399.99 - Original price $399.99
$399.99
3999 ENTRIES 🎟️
$399.99 - $399.99
$399.99
3999 ENTRIES 🎟️
S&S Cycle #: 31-6200
S&S billet oil pump assembly for 1936-1972 Big Twin models.
Assembly includes supply gears return gears drive shaft drive shaft keys drive shaft snap rings check ball check ball spring pressure valve pressure valve spring cover screws with o-rings hose fittings plugs screws paper gaskets and mounting hardware. Oil line available separately.
  • Suggested to use with Rigid Oil Line Set for Billet Pump
  • Suggested to use with Rigid Oil Line Set for Billet Pump Zicad Plated
1936-1940 EL
1941-1972 FL
1971-1972 FX
