Flywheel Thrust Washer Set - V-Twin 10-1153 - OEM 24100-17
479 ENTRIES 🎟️
479 ENTRIES 🎟️
OEM #: 24100-17, 358-17A
Crank pin flywheel inside washer set contains two more washers than the original set one thicker and one thinner than stock.
The 11-piece set contains one each of the following widths:.060.066.070.074.078.082.086.090.094.098 and.102.
- Inner Diameter: 1-1/4 inches
| 1936-1940 | EL |
| 1941-1954 | FL |
| 1937-1948 | UL |
| 1930-1934 | VL |
