93.4 Evolution Cylinder Kit Black - V-Twin 11-2628 - Evolution 1984-1998
Evolution 93.4 inch black cylinder kit includes Wiseco flat top 9.5:1 compression pistons with rings pre fitted to new 3-3/4 inch cylinders. Also included 2 head gaskets and 2 base gaskets.
Order rocker box gasket kit separately. Outer Diameter at the bottom of the cylinder is 98.38MM. *NOTE: Cases must be bored to accept kit. *NOTE: Will work with stock stroke Evolution flywheels.
- Outer Diameter: 98.38mm
- Case boring is required
| 1986-1998 | FLST |
| 1984-1998 | FLT |
| 1991-1998 | FXD |
| 1984-1994 | FXR |
| 1984-1998 | FXST |
