80 Shovelhead Front Cylinder - V-Twin 11-0481 - OEM 16567-78
OEM #: 16567-78
GME 80 inch front replacement cylinder for 1979-1985 Shovelhead.
GME front replacement cylinder is sold each without piston. The use of Colony 12 point Head Bolts 8714-20 chrome or 8618-20 black and cylinder base nuts 8600-8 chrome or 8601-8 black will allow extra clearance for tightening when necessary on 1948-1984 Big Twin cylinders. Inner diameter of the bore is 3.498 inch. *NOTE: All cast iron cylinders have same piston to wall clearance.0025 -.003.
- Suggested to use with #8601-8 Hi-Torque Cylinder Base Nut.
| 1966-1984 | FL |
| 1980-1984 | FLT |
| 1971-1984 | FX |
| 1982-1984 | FXR |
