74 Shovelhead Front Cylinder - V-Twin 11-0500 - OEM 16484-66
$199.99
1599 ENTRIES 🎟️
$199.99 - $199.99
$199.99
1599 ENTRIES 🎟️
OEM #: 16484-66
Front cylinder fits Shovelhead 1966-1978 74 inch models. Cylinders are for stock bore stock stroke and compression.
Cylinders must be honed to standard size for proper fit. Sold each. There are nine cooling fins on the cylinder. Piston is not included. *NOTE: All cast iron cylinders have same piston to wall clearance.0025 -.003.
  • Cylinder Base Height: 5/8 inches
1966-1978 FL
1971-1978 FX
