61 Knucklehead Rear Cylinder - V-Twin 11-0494 - OEM 16490-36
OEM #: 16490-36, 7-36C
Rear cylinder fits Knucklehead 1936-1947 61 inch models. Cylinders are for stock bore stock stroke and compression featuring 5 fins.
Cylinders must be honed to standard size for proper fit. Sold each. Piston is not included. *NOTE: All cast iron cylinders have same piston to wall clearance.0025 -.003.
| 1936-1940 | EL |
