Replica Shovelhead Cylinder Head Set - V-Twin 11-0082
Original price $1,219.99 - Original price $1,219.99
$1,219.99
9759 ENTRIES 🎟️
$1,219.99 - $1,219.99
$1,219.99
9759 ENTRIES 🎟️
Replica Shovelhead cylinder head set for Big Twin models.
Set is for stock lift cams only. Replica Shovelhead head sets feature rubber band type heads and are completely assembled with unleaded valve intake seats cast iron valve guides nitrated valves valve guide seals and stock type valve spring kit. Heads use long reach spark plugs and flat seals for the intake manifold. Heads fit all 1966-1984 Big Twins. Order stud set separately.
  • Recommended to use stud set.
1966-1984 FL
1971-1984 FX
