Panhead Top End Kit - V-Twin 11-5000
Panhead top end kit includes front and rear plumber style heads completely assembled with valve guides and springs rocker arm assemblies stainless Panhead covers and thick alloy d-rings.
Replica cylinder set is supplied with standard FLH 74 inch pistons fitted with rings to the cylinders. Includes stock plumber style intake manifold and seal kit to accept 4 bolt linkert carburetors. Essentially heads have components of Shovelhead intake and exhaust valves. For use with stock lift cams. *NOTE: Cylinder set includes original cast markings.
| 1948-1962 | FL |
