Panhead Cylinder Heads Full Assembly - V-Twin 10-1067
V-Twin Motor Shop Ready Panheads are fully assembled and ready to install.
Heads feature original contour castings with the added detail of the late style intake and Shovelhead exhaust port areas. Panheads are assembled with cast iron guides valve stem seals oilers and nitrated valves (Panhead exhaust/Shovelhead intake) in combination with a complete spring and collar set. Matched rocker arm assemblies are installed with heat treated studs & nuts. Order o-ring type intake manifold separately. Panhead cylinder heads accept outside overhead oil line. Accepts 74 inch and 80 inch Shovelhead cylinders.
- May require outside oiling.
- Suggested to use with Replica Alloy Intake Manifold.
