Shovelhead Ultima Engine Case Set Natural - Ultima 206-26 - Big Twin 1970-1984
Ultima #: 206-26
Shovelhead Ultima engine case set features a natural finish and a 3 piece flywheel design. Engine case features large bore breather for increased crank case vacuum and less blow by.
Set includes main bearings installed chromoly cylinder studs main seal spacer chrome timing hole plug case counterbores for socket head bolts stainless socket head casebolts alignment dowels for true line bore top end feed screen with spring and the oil pressue gauge. Engine case uses a 1992-up oil pump and has a 3.625 inch bore.
| 1970-1984 | FL |
| 1970-1984 | FX |
