Shovelhead Ultima Engine Case Set Black - Ultima 206-29 - Big Twin 1970-1984
by Ultima
Original price $959.99 - Original price $959.99
$959.99
9599 ENTRIES 🎟️
$959.99 - $959.99
$959.99
9599 ENTRIES 🎟️
Ultima #: 206-29
Shovelhead Ultima engine case set features a black finish and a 5 piece flywheel design. Engine case features large bore breather for increased crank case vacuum and less blow by.
5 piece fly wheel designs have their pinion race sized to 1.751 inch and utilize the 'white' pinion bearing. Set includes main bearings installed chromoly cylinder studs main seal spacer chrome timing hole plug case counterbores for socket head bolts stainless socket head casebolts alignment dowels for true line bore top end feed screen with spring and the oil pressue gauge. Engine case features a stock bore 74 C.I. & 80 C.I. and uses 1984-1991 EVO oil pump.
1970-1984 FL
1970-1984 FX
