S&S Engine Crankcase Set - S&S Cycle 106-4039 - Twin Cam 2000-2006
Original price $1,779.99 - Original price $1,779.99
$1,779.99
14239 ENTRIES 🎟️
$1,779.99 - $1,779.99
$1,779.99
14239 ENTRIES 🎟️
S&S Cycle #: 106-4039
Crankcase set for 2000-2006 TC-88A engine with stock bore engine with stock bore and comes ready to assemble.
S&S crankcase set includes Timken left side bearing race assembly seal seal spacer oil pump drive bushing needle bearing pinion race for right side is pressed in and line honed ready to assemble. Also included are cylinder studs nickel plated case bolts crankcase fittings and a timing and magnetic drain plug. Crankcase bore is stock and will accept flywheels up to 8-1/2 inch diameter. This crankcase is compatible with the stock primary and charging system. *Note: Stock oil pump required for assembly. Manufacturer's Statement of Origin is supplied.
2000-2006 FLST
2000-2006 FLT
2000-2005 FXD
2000-2006 FXST
