Right Side Engine Case - V-Twin 10-0977 - OEM 24556-37
OEM #: 24556-37, 410-37A
45 inch right side engine case includes bronze cam bushings installed.
*NOTE: This is the right hand case requires case race to be installed when paired with V-Twin Left Side Engine Case or builders own case. Deck height and motor mount pads must be matched together. Cases when paired must be line honed (races) with sunnen hone. Our motor shop can perform the entire service.
- Required to use with #9697-17 Engine Case Kit Parkerized
| 1937-1973 | G |
| 1937-1952 | W |
