Extreme Heavy Duty Left Side Main Bearing Kit - Eastern A-24004-03B - OEM 24004-03B - Twin Cam 2003+
by Eastern
$109.99
879 ENTRIES 🎟️
$109.99 - $109.99
$109.99
879 ENTRIES 🎟️
Eastern #: A-24004-03B · OEM #: 24004-03B
Extreme duty left side main bearing kit is for all 2003-UP Twin Cam and M8 models. Includes bearing spacer thrust washers and snap ring.
When high-performance engine modifications are made the increased torque is transferred via the crankshaft to the drive system putting a significantly higher load on the bearing. The extreme duty bearing is case hardened on the inner and outer race to provide increased load capacity and enhanced durability in high-torque applications. Installed in the left side of the crank case and supports the output shaft to the primary drive system.
2003-2017 FLST
2003-UP FLT
2003-2017 FXD
2003-2017 FXST
