Roller Bearing Set with Cages - V-Twin 10-0787
719 ENTRIES 🎟️
719 ENTRIES 🎟️
Bearing set is a 1954 factory style upgrade which is used on the right side comes with 2 narrow cages and uses a large outer diameter roller 1/4 inch.
The spacer is.434 inch wide we are eliminating the OEM #24695-40.122 inch thick spacer. Includes OEM #9321 24 pieces of a 1/4 inch x.360 inch roller bearings 2 of OEM #24646-54.434 inch wide bearing cages 1 of OEM #24690-40 bearing washer and 1 of OEM #24702-40 snap ring. *NOTE: Requires installation of OEM #24599-40 right side races.
1936-1952 EL
1941-1954 FL
