Standard Cam Chest Breather Valve Gear - V-Twin 12-0788
$109.99
$109.99
$109.99
879 ENTRIES 🎟️
$109.99
$109.99
$109.99
879 ENTRIES 🎟️
Standard size cam chest breather valve gear is machined and designed to replace original ground steel units.
Order 8 piece thrust washer separately. *NOTE: 28.45mm (1.1201 inch) outer diameter.
- Suggested to use with Cam Chest Breather Valve Washer Set.
| 1936-1940 | EL |
| 1941-1947 | FL |
