S&S Steel Cam Chest Breather Valve - S&S Cycle 33-4246 - OEM 25300-36
by S&S Cycle
$139.99
$139.99
$139.99
1119 ENTRIES 🎟️
$139.99
$139.99
$139.99
1119 ENTRIES 🎟️
S&S Cycle #: 33-4246 · OEM #: 25300-36, 504-36
S&S steel cam chest breather valve with standard 1.121 inch outer diameter. Features a inchT inch shaped timing mark and does not have groove cut on the bottom of the gear.
*NOTE: Requires the use of the late style thrust washer.
- Suggested to use with S&S Breather Cam Chest Washer Set.
- Suggested to use with Cam Chest Breather Valve Washer Set.
| 1948-1977 | FL |
| 1971-1977 | FX |
