Circuit Breaker Drive Gear - V-Twin 12-1396 - OEM 25850-36A
$99.99
$99.99
$99.99
799 ENTRIES 🎟️
$99.99
$99.99
$99.99
799 ENTRIES 🎟️
OEM #: 25850-36A
Circuit breaker drive gear includes inner and outer pressed in bearings.
*NOTE: When installing drive gear first check the fitment of the side drive circuit breaker idler gear. *NOTE: Bushings my require reaming to fit the idler and circuit breaker studs in the case.
- Diameter: 1.107 inches
| 1936-1940 | EL |
| 1941-1969 | FL |
