Andrews Cam Set Late Gear Drive #TW31S - Andrews 216331G - Twin Cam 2006-2017
by Andrews
$249.99
$249.99
$249.99
1999 ENTRIES 🎟️
$249.99
$249.99
$249.99
1999 ENTRIES 🎟️
Andrews #: 216331G
Andrews late gear drive cam set is a great cam for motors with 95 inch+ engines and 10:1 compression ratio. Cam lift is.510. Lower TDC lift means easy install like 37 cam but different timing. 2000-5800 RPM.
Set of four. **NOTE: Requires the use of an S&S gear drive.
- Order S&S gear drive kit
| 2007-2017 | FLST |
| 2007-2016 | FLT |
| 2006-2017 | FXD |
| 2007-2017 | FXST |
