Andrews Cam Set Late Gear Drive #67HG - Andrews 216367G - Twin Cam 2006-2017
by Andrews
$279.99
$279.99
$279.99
2239 ENTRIES 🎟️
$279.99
$279.99
$279.99
2239 ENTRIES 🎟️
Andrews #: 216367G
Andrews late gear drive cam set is a performance cam for 95 inch to 107 inch engines with 10:0 to 10:8 compression ratio with high flow head set-up (2600-6400+ RPM).
**NOTE:Requires S&S gear drive use with hi-lift springs.
- Order S&S gear drive kit
| 2007-2017 | FLST |
| 2007-2016 | FLT |
| 2006-2017 | FXD |
| 2007-2017 | FXST |
