Andrews Cam Set Early Gear Drive #64G - Andrews 288164G - Twin Cam 1999-2006
by Andrews
$559.99
$559.99
$559.99
5599 ENTRIES 🎟️
$559.99
$559.99
$559.99
5599 ENTRIES 🎟️
Andrews #: 288164G
Andrews early gear drive cam set features big cams for modified 95 inch-116 inch+ motors running 10:2 compression ratio or higher.
Heads must be set for.700 lift and modified for maximum air flow (3000-65000 RPMs) **NOTE:Requires S&S gear drive.
- Order S&S gear drive kit
| 1999-2006 | FLST |
| 1999-2006 | FLT |
| 1999-2005 | FXD |
| 1999-2006 | FXST |
