Replica UL Smooth Cam Cover - V-Twin 10-1935
$409.99
3279 ENTRIES 🎟️
$409.99 - $409.99
$409.99
3279 ENTRIES 🎟️
Replica cam cover includes bushings spring and deflector assembly installed. Features a smooth natural finish as used on 74 inch and 80 inch 1937-48 UL and ULH models to replace finned cover.
*NOTE: The 5 bronze bushings installed may require reaming for each application. Order Screws and gasket separately. **NOTE: The technician must install breather valve V-Twin in hole as shown. The hole must be drilled to size then pressed in. Pinion bushing must be replaced and re-installed with slot opposite feed hole in cover. *NOTE: Distributor shaft hole will require reaming for proper fit. Check Magneto or distributor shaft before reaming to fit. ***NOTE: Will also fit 1947-1948 VL to replace finned cover.
1937-1948 UL
1940-1948 ULH
