Oil Pressure Switch - V-Twin 12-1402 - OEM 26551-39
359 ENTRIES 🎟️
359 ENTRIES 🎟️
OEM #: 26551-39, 480-39
Replica oil pressure switches are precision calibrated and feature heavy contacts brass pressure ferrules thermo- plastic insulators and brightly finished steel shells. Oil pressure switch has a 4-6 pound range.
When fitted to 1936-1940 EL you must use an oil pressure sender unit extension. *NOTE: Must use a brass sealing washer not included.
  • Thread Pitch: 3-8/24 inches
  • Suggested to use with Oil Fitting Washer.
  • Suggested to use with Parkerized Oil Pressure Sender Unit Extension when fitted to 1936-1940 EL.
1938-1940 EL
1941-1969 FL
1938-1947 UL
