Harley Pulley Brake Disc Spacer Alloy 1 Thickness - York 63185 - Big Twin 0+
by York
SKU 20-0145
449 ENTRIES 🎟️
449 ENTRIES 🎟️
Alloy 1 inch thick rear pulley rotor spacer has 5 holes and 7/16 inch bolt holes. This spacer is ideal to get belt pulleys and chain sprockets in line. Spacer can be machined down to the next size under without having to worry about the spigot alignment when you machine the face of the spacer down to desired thickness. Spacers are drilled for use with 7/16 inch bolts and designed to be used with 2000-UP type wheel hubs. Universal fit for most Harley applications.
York #: 63185
  • Inner Diameter: 2.25 inches
