Clutch Drum Kit - V-Twin 18-0551 - Ironhead 1971-1980
Drum kit is for kick starter and electric start models.
Kit includes clutch backing plate with stud spacer set Magnum clutch kit steel clutch set inner and outer clutch springs clutch release disc thrust bearing collar disc bearing with 2 shields outer drive clutch plate clutch drum retainer clutch hub nut and lock clutch drum with ratchet clutch hub bearing transmission main bearing snap ring clutch retainer kit with nuts and clutch hub.
| 1971-1980 | XL |
