51 Tooth Splined Rear Sprocket - V-Twin 19-0173
$119.99
959 ENTRIES 🎟️
$119.99 - $119.99
$119.99
959 ENTRIES 🎟️
51 tooth splined engine rear sprocket is nickel plated.
WR-KR-XR sprockets have a.350 inch offset from the center of the spline to the center of the tooth profile. This is 8 tooth spline and 9.9mm at the widest point on spline. V-Twin's KR-XL-WR sprockets can be used with 530 wide chains. *NOTE: 530 chain sprockets has splines to fit WR-XR-KR quick change hub. *NOTE: WR and JD splines do not interchange.
1952-1956 KR
1930-1937 RL
1970-1980 XR
