Harley Big Twin & Sportster Yellow Super Coil for Points Ignition - Accel 140406 - Ironhead 1965-1979
Accel dual fire super coil is designed to deliver the maximum amount of spark energy faster rise times and 45% higher voltage to the plugs. Coil is for points style ignition. The super coil mounts in most stock locations and will fit under most OEM and aftermarket coil covers. This coil is for a points type ignition and comes in a yellow finish. Coil has 4.7 Ohms. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. Fits 1965-1979 Harley Sportster, Panhead, and Shovelhead models.
Accel #: 140406
| 1965-1979 | FL |
| 1971-1979 | FX |
| 1971-1979 | XL |
