XL Gas Tank 2.4 Gallon Raw - V-Twin 38-0105 - Ironhead 1979-1981
SKU 38-0105
$179.99
1799 ENTRIES 🎟️
$179.99 - $179.99
$179.99
1799 ENTRIES 🎟️
Raw replica stock gas tank is single cap style with a right side petcock location and a fuel capacity of 2.4 gallons.
High tunnel stock style tank features stock mounts and filler neck. It uses a 1975-up petcock. The mount tabs are 15 inch from the front center tab to the center rear tab. Please test fitment before painting. Tank weld seams may require filler to meet your individual requirements. Do not grind or sand the seams as this may cause leaks. We suggest using Kreem gas tank combo kit to clean condition and seal. This will help top stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. The petcock fitting should be masked or plugged during painting for easy installation of the petcock. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Top Length: 16-1/2 inches
  • Bottom Length: 13 inches
  • Rear Width: 4 inches
  • Front Width: 8-1/2 inches
  • Rear Height: 3 inches
  • Front Height: 7 inches
  • Front Tunnel Height: 3-1/2 inches
  • Rear Tunnel Height: 1/2 inches
  • Tunnel Length: 17 inches
1979-1981 XL
