Harley Wyatt Gatling Inverted Air Filter Kit - V-Twin 34-1334 - Big Twin 0+
SKU 34-1334
649 ENTRIES 🎟️
649 ENTRIES 🎟️
Wyatt Gatling inverted air filter kit mounts with center screw. The filter is round cleanable type and fits Screamin Eagle and Wyatt Gatling with 3 stud mounting. Kit includes tapered inverted air filter 3 studs for mounting cross bar and a 5/16 inch X 18 inch X 3/4 inch button head screw for attaching to center mount bracket. Inverted design allows for more air flow! For use with appropriate backing plate for specific application. The diameter measures 5 inch at the smallest part of the filter and 6-1/4 inch at its widest. NOTE: For all tapered air filter applications with 3 stud mounting. Universal fit for most Harley applications.
  • Can be substituted with Velocity Type Tapered Air Filter for more air flow.
  • Suggested to use with Air Cleaner Mount Stud Set and Air Cleaner Adapter Flange.
0 Replacement
