Harley Flathead WR Front Spool Hub - V-Twin 45-0102
Front spool hub is nickel plated and includes 3/8 inch internal ball bearings that accepts stock WL 45 axle and nuts. Includes a 3/8 inch inner diameter threaded sleeve to adapt the sealed ball bearings on each side. Will accept a 4.9 inch wide axle and nuts for use on WL 45 Spring Forks with inside rocker configuration. Center tube of hub measures to be 6.5 inch. Does not require spacers for installation on WL fork assemblies. For use on 18 inch rim stainless steel spoke set. The distance between the inside of the rocker on a 45 WL spring fork measyres 6-1/2 inch. *NOTE: Hub is fitted with sealed ball bearings and a spacer with a 3/8 inch inner diameter. Hub width measures 5 inch. Grease fitting holes is tapped 5/16 inch x 32. Order tap tool if needed. *NOTE: Accepts 6-8 gauge spokes. The crease fitting is for cosmetic looks only. Order 7/16 inch axle separately. Fits 1930-1952 Harley Flathead models.
- Width: 5 inches
- Suggested to use with Tap Tool.
- Suggested to use with 18inch WR Spoke Set.
- Suggested to use with 7/16inch-20 Front Axle
| 1930-1952 | W |
