Harley Flathead WR 45 Right Footpeg Mount Parkerized - V-Twin 49-1486
SKU 49-1486
$169.99
1699 ENTRIES 🎟️
$169.99 - $169.99
$169.99
1699 ENTRIES 🎟️
Reproduction of WR WLDR or WRTT right footpeg bracket kit. This mounts the peg directly to the sprocket cover on the right side of weight and moving the driver's foot back a bit where it can work with the stubby brake pedal. The hex spacers are threaded 5/16 inch-24 same as the sprocket cover studs. These will mount in place of the nuts used to secure the sprocket cover. *NOTE: Also available is the right side 1 piece WR brake pedal. This allows the footboard side strap to be removed for a weight saving. Brake pedal connects directly to the rear brake rod. *NOTE: This kit requires use of a shortened transmission filler plug not included. Fits 1936-1952 Harley Flathead models.
  • For use with WL Rear Support Rod in place of stock WL bull crank rear brake rod functions as normal.
1936-1952 WL
