Harley Volt Tech Rust 6 Volt Coil - Volt Tech 10-2022 - OEM 31609-65 - Sportster 0+
SKU 32-0711
$84.99
849 ENTRIES 🎟️
$84.99 - $84.99
$84.99
849 ENTRIES 🎟️
Volt Tech replica coil is factory replacement quality to fit stock brackets. Coil is 1.3 OHM 6 volt type and is rust colored. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. Universal fit for most Harley applications.
Volt Tech #: 10-2022 · OEM #: 31609-65
0 Special
