Harley Volt Tech Chrome Single Fire Coil - Volt Tech 10-2002C
Single fire coil by Volt-Tech features 45kv with one spark for each cylinder as fired. Coil is chrome and 2.4 ohms. Mounts to stock bracket and accepts stock type coil covers. Works with most aftermarket single fire ignition systems. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. Universal fit for most Harley applications.
Volt Tech #: 10-2002C
- Width: 3-1/4 inches
- Height: 2-5/8 inches
- Length: 3-1/8 inches
| 0 | Special |
